xnviewmp 1.5.2 - AVIF files won't open.
xmozg
Post by xmozg »
win10x64 xnviewmp 1.5.2 x64
I download or I save the file in AVIF format within xnviewmp, and xnview always opens it as a video with a black square and video control at the bottom.
Nothing more to say)
masterjp
Re: xnviewmp 1.5.2 - AVIF files won't open.
Post by masterjp »
Hello, I use XnviewMP 1.5.2 and there are no problems with avif files under windows 10 64bit.
How do you open your avif files?
Do you open them from browser windows of XnViewMP or in windows explorer (double click)?
Do you have a sample file?
xmozg
Post by xmozg »
I'm installing the program versions on top, and maybe because of previous versions (bug), in the settings file list > custom filter in the column "video - other" was entered avif format. I discovered this, removed it, and now avif images open properly in xnviewmp.
