1.5.2 Newly assigned shortcut is not working when reusing shortcuts
XnSoldier
Post by XnSoldier »
I have assigned ctrl-I to "select all images" after disabling it for the function "edit IPTC". I had selected "none" for the latter function before that.
But it actually doesn't work for the new function. Nothing happens. (ctrl-I assigned to "select all images")
It shows in the menu with the new shortcut. The menu function does work but not the shortcut itself.
When I assign a different shortcut (which was not in use like Alt-A) it worked. Then I assigned ctrl-I again and now it worked.
But it repeats if I assign another shortcut which had just been disabled (like F7 for creating a new folder). Not working although menu and settings confirms it being F7. Just entering and assigning it again doesn't work either.
Photographer. Sorting 250.000 pics per year
20 years with ACDSee Photo Professional. Love and Hate. I would love to see XnView MP upgraded for better editing or a commercial "XnPhoto Pro"! Keep up the work!
Re: 1.5.2 Newly assigned shortcut is not working when reusing shortcuts
XnSoldier
Post by XnSoldier »
Great. Pls make reassigning shortcuts easier so that users don't have to lookup the currently assigned function first and then assign the new shortcut. Thanks!
in 1.8.0?
