Browser - folders - widen folder selection
XnViewMP 1.5.2
Browser - folders
its not possible to select folder by clicking on its line, you have to click on the name
  • expand folder selection indicator from edge-to-edge like in windows File explorer
Example
Related
Re: Browser - folders - widen selection all way to the right
What do you see as the benefit?
What is normal practice in other software?
updated post with few details
cday wrote: Wed Aug 02, 2023 7:01 am What do you see as the benefit?
- easy to select an item by clicking on the line, instead of name only
- enhance visual indication of the selected item
- edge-to-edge selection just looks better (no broken lines)
cday wrote: Wed Aug 02, 2023 7:01 am What is normal practice in other software?
I would stick to windows File explorer as standard
Re: Browser - folders - widen folder selection
it's not possible, Qt behavior
Selection in Catalog Filter is widen all the way to the right
Is it possible to make the same for:
- Folders
- Favorites
yes, but children are not all expanded (and created) in folder tree view... so here i can't
but it it should not depend on children, column should always auto stretch to the widget size
aren't Folders and Catalog Filter using same QTreeView?
that has QHeaderView::ResizeMode, guess this is similar use case
