screen show.
MJL
screen show.
Post by MJL »
Classic screen show uses left and right clicks to move forward and backward through the file.s
MP only goes forward, whichever button is clicked. This seems to have been the case since launch. Limitation or bug?
Re: screen show.
Maybe a settings issue?
Please check your Tools > Settings... > Interface -- Mouse tab settings.
MJL
Re: screen show.
Post by MJL »
If there is, I cannot find it.....
Re: screen show.
In Tools > Settings... > Interface -- Mouse tab the Left button can be set to Previous file and the Right button to Next file...
My settings, different mouse options selected:
MJL
Re: screen show.
Post by MJL »
Thanks :) :) :)
MJL
Re: screen show.
Post by MJL »
OK, I have now worked out what is going on..
On Classic, there were no options in Settings to change the mouse buttons - on a slide show left and right buttons forward and reverse the slides
On MP, the new mouse settings only apply when browsing a folder of files. They have no effect on a slide show, where every button just steps forward.
So i guess a limitation of MP.
