1.5.2: Empty "Size" label is not hidden when "File Type" is presented
sad comrade
Post by sad comrade »
XnView: MP 1.5.2 - 64 bit
OS: Windows 64bit
Empty (({Size})) label is not hidden when there is a {File Type} label on the same line.
Effect: Size is displayed as "0 Bytes"
1. Go to Settings > Thumbnail > Labels
2. Add a custom labels line:
foo (({File Type})) (({Size}))
3. Add another custom labels line:
foo (({Size}))
4. Confirm setting change
5. Examine thumbnails for a file and for a directory
Actual behaviour (bug):
  1. "foo (({File Type})) (({Size}))" is displayed:
    1. for directory as foo··0·Bytes ("·" is a space character)
    2. for file as foo·JPG·207.03·KiB
  2. "foo (({Size}))" is displayed:
    1. for directory as ·
    2. for file as foo·207.03·KiB
Expected behaviour: Empty (({Size})) should be hidden disregarding of other labels presence - "foo (({File Type})) (({Size}))" > "foo". Also it's kind of strange that foo is removed from result of "foo (({Size}))" if Size is empty
Re: 1.5.2: Empty "Size" label is not hidden when "File Type" is presented
This problem is supposed to be fixed in XnView MP 1.5.4. Please check and confirm the bug fix here.
sad comrade
I confirm the bug has been fixed in 1.5.4
