Where is map view for GPS tagged photo?
FKCapitalism2
Post by FKCapitalism2 »
If i remember correctly there used to be map view for GPS tagged photos, i cannot locate it anymore.
Only thing i find is Metadata > Open GPS location in... menu
Re: Where is map view for GPS tagged photo?
it's in Info panel
FKCapitalism2
xnview wrote: Sat Aug 12, 2023 8:47 am it's in Info panel
Oh in my case i closed info panel completely because never used it.
Post by michel038 »
You can also use right click > properties in view mode. This window can be resized...
FKCapitalism2
michel038 wrote: Mon Aug 14, 2023 7:20 am You can also use right click > properties in view mode. This window can be resized...
Problem is its for single image only, i want same functionality as in Lightroom/ACDSee where you can see map with images in the folder and can navigate not by thumbnails view, but by map view and open images that i need.
For instance i was walking in the park and taking pictures along the way, i can open map of the park and find the monument then zoom in map and see all the photos that were taken near that monument.
First half of the video shows this functionality
https://www.youtube.com/watch?v=UnSXz0ckFno
Post by michel038 »
I'm using PicaGeoTag freeware
It can read/create/update gpx files (GPS tracks)
It shows photos on a map
You can move or add photos on the map
You can have photos with no GPS coordinates automatically distributed on the map by interpolating the date/time/taken, and update their exif gps data.
FKCapitalism2
michel038 wrote: Wed Aug 16, 2023 2:01 pm I'm using PicaGeoTag freeware
Would be nice to have this functionality in XNView MP.
FKCapitalism2 wrote: Thu Aug 17, 2023 2:15 pm
Please make a post in Suggestions
DavidGDFC
Post by DavidGDFC »
I was wondering if there are any updates on this topic. I had a look on the 'Suggestions' section, but couldn't find anything. Also, I checked on version 1.9.8.
I agree that it would be great if you could select a folder (with its subfolders), or even a number of folders, and see the location of the every picture on the same map.
