1.5.3 - web capture - stuck at "Generating image..." dialog
XnViewMP 1.5.3 64bit
Viewer/Browser - web capture
enter any web address, press OK
issue A
issue B
progress bar does not reach right end, same as here (Issue A)
xmozg
Re: 1.5.3 - web capture - stuck at "Generating image..." dialog
Post by xmozg »
user0 wrote: Sat Aug 12, 2023 5:36 amstuck at "Generating image..." dialog
Yes. But if I need to capture a page, I use the vivaldi "capture page to file" function. Maybe replace the menu item "Web Capture" with "Download Vivaldi for Web Capture and more"? joking.
"Generating image..." dialog has same issues as described
Not issue. QT feature.
xmozg wrote: Sat Aug 12, 2023 7:10 am
most of the browsers have this build-in functionality, but thats not the subject of this post
yeah, feature, lol
apart from resizing there is another issue with progress bar control size
Since i don't use WebKit or QtWebEngine anymore, i remove it
xmozg
Post by xmozg »
user0 wrote: Sat Aug 12, 2023 7:52 am most of the browsers have this build-in functionality, but thats not the subject of this post
Not subject, but I doubt that. But in any case, the mention of the browser was a joke.
yeah, feature, lol
All I had to do was look at this (your) thread -
viewtopic.php?f=104&t=45374
and see answer
xnview wrote: Thu May 25, 2023 1:31 pm With Qt, all dialogs are resizable...
And google "xnview web capture" to see this thread -
https://forum.xnview.com/viewtopic.php?t=32909
where it says web capture uses QT. So, logical conclusion is... (drumroll) for this feature, resizing dialogs is not a bug, but a feature.
xmozg wrote: Sat Aug 12, 2023 7:00 pm
yeah, feature, lol
oops, my bad, I referenced wrong issue
it should be not issue C "resizable dialog", but A "progress bar does not reach right end"
I will update my post
This problem is supposed to be fixed in XnView MP 1.5.4. Please check and confirm the bug fix here.
fixed in 1.5.4
