1.5.3: XnView crashes if you press Esc upon "file not found" dialog
fireattack
Post by fireattack »
Related to: viewtopic.php?f=62&t=44405
1. Rename a file to include full-width quote, such as
2. Double click on the file, to try to open it with XnView MP.
3. A dialog shows "file not found" due to bug mentioned in this post.
4. (A different crash bug) Press Esc when this dialog shows.
5. XnView crashes.
Re: 1.5.3: XnView crashes if you press Esc upon "file not found" dialog
I can't reproduce, an empty tab is opened. Do you have sent the crash dump?
fireattack
Yes, I've submitted multiple. But here is another one I just generated:
81de232f-b281-402a-8132-68279ffb722e.zip
(21.64 KiB) Downloaded 20 times
ok seems the same as this one
This problem is supposed to be fixed in XnView MP 1.5.4. Please check and confirm the bug fix here.
fireattack
Verified fixed
