8bi Photoshop Plugins not detected
FaceCrap
Post by FaceCrap »
Ok, I give up, I've tried three ways from Sunday,
I can add the folder through Effect > Adobe Photoshop Plugin... > Configure, but after clicking OK, the dialog I return to stays blank...
So next I added a 8bf folder like exists for XNview, copied the plugin folder into it, but no go there either.
Thought ok, maybe needs an 8bi folder (since it's an 8bi plugin, not an 8bf) but that too didn't work.
Re: 8bi Photoshop Plugins not detected
I'm not sure that 8bi is same as 8bf, could you send me a example file?
XnView Classic and MP support Photoshop-compatible filters (.8bf). .8bi OTOH are file format plug-ins.
Examples:
%ProgramFiles%\Adobe\Adobe Photoshop CS2\Plug-Ins\Adobe ImageReady Only\File Formats\QuicEPS.8bi
%ProgramFiles%\Adobe\Adobe Photoshop CS2\Plug-Ins\Adobe ImageReady Only\File Formats\TIFF.8bi
%ProgramFiles%\Adobe\Adobe Photoshop CS2\Plug-Ins\Adobe Photoshop Only\File Formats\Cineon.8bi
%ProgramFiles%\Adobe\Adobe Photoshop CS2\Plug-Ins\Adobe Photoshop Only\File Formats\Gif.8bi
%ProgramFiles%\Adobe\Adobe Photoshop CS2\Plug-Ins\Adobe Photoshop Only\File Formats\OpenEXR.8BI
%ProgramFiles%\Adobe\Adobe Photoshop CS2\Plug-Ins\Adobe Photoshop Only\File Formats\PBM.8BI
%ProgramFiles%\Adobe\Adobe Photoshop CS2\Plug-Ins\Adobe Photoshop Only\File Formats\Png.8bi
%ProgramFiles%\Adobe\Adobe Photoshop CS2\Plug-Ins\Adobe Photoshop Only\File Formats\Radiance.8BI
%ProgramFiles%\Adobe\Adobe Photoshop CS2\Plug-Ins\Adobe Photoshop Only\File Formats\WBMP.8BI
%ProgramFiles%\Adobe\Adobe Photoshop CS2\Plug-Ins\File Formats\BMP.8BI
%ProgramFiles%\Adobe\Adobe Photoshop CS2\Plug-Ins\File Formats\FilmStrip.8BI
%ProgramFiles%\Adobe\Adobe Photoshop CS2\Plug-Ins\File Formats\PCX.8BI
%ProgramFiles%\Adobe\Adobe Photoshop CS2\Plug-Ins\File Formats\Photo CD.8BI
%ProgramFiles%\Adobe\Adobe Photoshop CS2\Plug-Ins\File Formats\Pixar.8BI
%ProgramFiles%\Adobe\Adobe Photoshop CS2\Plug-Ins\File Formats\Targa.8BI
%ProgramFiles%\Common Files\Adobe\Plug-Ins\CS2\File Formats\Camera Raw.8BI
\Goodies\Optional Plug-Ins\File Format\Alias.8BI
\Goodies\Optional Plug-Ins\File Format\ElectricImage.8BI
\Goodies\Optional Plug-Ins\File Format\IFF Format.8BI
\Goodies\Optional Plug-Ins\File Format\Rla.8bi
\Goodies\Optional Plug-Ins\File Format\Sgirgb.8bi
\Goodies\Optional Plug-Ins\File Format\SoftImage.8BI
\Goodies\Optional Plug-Ins\Photoshop Only\File Formats\JPEG2000.8BI
\Goodies\Optional Plug-Ins\Photoshop Only\File Formats\Mac Paint.8BI
\Goodies\Optional Plug-Ins\Photoshop Only\File Formats\PIXPNT8B.8BI
FaceCrap
Post by FaceCrap »
xnview wrote: Tue Aug 15, 2023 8:00 am I'm not sure that 8bi is same as 8bf, could you send me a example file?
As the next poster indicated, they are indeed not the same thing.
XnTriq wrote: Tue Aug 15, 2023 7:45 pm XnView Classic and MP support Photoshop-compatible filters (.8bf). .8bi OTOH are file format plug-ins.
Thank you, that explains a lot. I never used Photoshop or plugins for it before, so didn't know there are different types.
