1.5.0 64bits: Tab Key Behaviour
FaceCrap
Post by FaceCrap »
XnView MP Windows: Version 1.5.0 64bits (Jul 10 2023)
OS: Windows 64bit
When pressing tab to go to the next image (like in Windows Explorer), instead XnViewMP goes to the next row (e.g. like when pressing arrow down)
Effect: Irritation because the behaviour is contradictory to the regular Windows Explorer behavior
1. Press F2 to rename an image
2. Type new name
3. Press Tab Key
Actual behaviour (bug): Input focus goes to the image below the current image.
Expected behaviour: Input focus going to the next image on the right in the same row, or the first image on the next row if this was the last image in the current row.
Re: 1.5.0 64bits: Tab Key Behaviour
yes right, in list mode, it's ok. It seems that it's a bug in Qt API
