Paste path to the Save dialog (XnViewMP 1.5.3/Mac)
alik1006
Post by alik1006 »
When I try to save edited picture to a specific folder, I go to "Save File" dialog and then I press "/" to open "Go To Folder" (I assume it's a standard Finder dialog). However, when I try to paste path from clipboard nothing happens as if clipboard was empty. Somehow it works in any other application for me (so far). Is there a way to make it work? Did I miss something? It is really inconvenient to manually go through all the folders to get to the right place to save file to...
Thank you.
Re: Paste path to the Save dialog (XnViewMP 1.5.3/Mac)
you're right but i don't know why it's not working, perhaps a Qt bug
