Missing lmath-3_2.dll
Lbar
Post by Lbar »
I have installed version 1.98 (had 1.96 before) on a Windows 8.1 pro computer.
When I run XnConvert it shows twice a message saying that the lmath-3_2.dll is missing. After confirming the two messages XnConvert starts but it is not working properly.
I run the installation again, as suggested in the message, but nothing changed.
Any idea of what can I do?
Thanks. Luis.
Re: Missing lmath-3_2.dll
right a problem in the package...
Seaton
Post by Seaton »
The same issue here - OS Win7 - 64bit installed vers 1.98 update but also didn't help
Seaton
Post by Seaton »
https://support.microsoft.com/en-us/win ... 92228dfd85
To trouble shoot DirectX problems:
1) In Windows, select Start and enter <dxdiag> into the search box on the taskbar & Select <dxdiag>
In the tool, select Save All Information for an easily shared format ie...to desktop.
No DirectX issues were found.
2) Free version CCleaner's (registry cleaner) found remnants of 12 deleted files (some Adobe) that needing to be deleted.
After rebooting XnView MP now loads - however some of my downloaded Internet Archives PDF's still crash?
Ivanov391
Post by Ivanov391 »
Hi.
Download XnView MP ZIP package and extract all needed DLL files from plugins directory into the same path in installed XnConvert, which it will ask for missing at start.
For me it was: Imath-3_2.dll, IlmThread-3_2.dll, Iex-3_2.dll.
Enjoy!)
Seaton
Post by Seaton »
Thanks Ivanov I will follow your suggestion.
What I posted just doesn't work - later on I noticed I had been fidling with the XnView MP file which works perfectly, instead of the XnConvert file requesting a missing Imath-3_2.dll. I appologise for any inconvieniance this mistake may have caused.
