Hello.
I have used the function "Find similar files". I used other software as well. I think XnView gives better results, but in front of other software, it lacks some basilar features for this function.
In my opinion, it would be very useful, when it finds duplicate, that it shows how many files duplicate found and how many are the reference files. It could be very helpful, if it would be possible to export the results in csv and html files. In the html files, there should be the preview of the reference and duplicate files with the source path for each.
Kind regards
Find similar files: improvement
