1.5.3 - browser - thumbnail autorotation
XnViewMP 1.5.3 64bit
Browser
not sure why autorotation applied to this image's thumbnail
test_img_autorotation.zip
(1.44 MiB) Downloaded 240 times
Re: 1.5.3 - browser - thumbnail autorotation
no problem in 1.5.3, try 'update catalog from files'?
yep, I use 1.5.3
- it happens with clean unzipped version of xnviewmp
- nothing helps: neither 'Update catalog from files', nor 'Update files from catalog', nor 'Rebuild thumbnails'
- issue also remains when I delete all Catalog entries and disable it
I assume it autorotation feature (since there is related overlay icon) that wrongly applies for some reason
without catalog?
same issue, even if I disable Catalog AND delete Thumbs.db
right, it's because i can't use latest version of heic.dll
fixed in 160b (231003)
This problem is supposed to be fixed in XnView MP 1.6.0. Please check and confirm the bug fix here.
