Using Fotostation software for several years, I recently switched to XnView. However I noticed that the use of some IPTC fields is different. Now I should like to move the content from several IPTC fields from one to another. As I have to do this for about 10.000 pictures, I have searched an solution to do this in a batch. Can anybody tell me if this possible in XnView?
greetings René
Move content IPTC fields to other IPTC fields
Re: Move content IPTC fields to other IPTC fields
Which differences do you have?rbeek wrote:Using Fotostation software for several years, I recently switched to XnView. However I noticed that the use of some IPTC fields is different. Now I should like to move the content from several IPTC fields from one to another. As I have to do this for about 10.000 pictures, I have searched an solution to do this in a batch. Can anybody tell me if this possible in XnView?
rbeek
Hello Pierre,
I have 4 fields in which the content has to move tot another field.
(or do you want to know the exact name of the fields?)
greetings René
greetings René
Why move? These fields don't exist in XnView??rbeek wrote:I have 4 fields in which the content has to move tot another field.
rbeek
Hello Pierre,
Let me try to explain; the content in the field 'Copyright' on Tab four, should me moved to the field 'Head' on Tab one.
This is an example. But in this way I should move the content of four fields to other fields.
greetings René
greetings René
