Auto Update and Continuous Display of 2 Images Side by Side at Once
v1nc3
Post by v1nc3 »
I would like to suggest that this wonderful program do two, IMO important, things:
(1) Auto Update - Check for updates, prompt to install update, download the update and apply the update. No more download it manually.
(2) The ability to display 2 images at the same time, side by side like Neeview, for example. Ability to keep doing this backwards and forwards through a directory contents. Also would be good if the program fully supported cbr and cbz formats and read these comic files and displayed images (pages) one or 2 at a time like in ex (2).
Thank you, hope this does happen and the need is seen and implemented. I'm a long time user (YEARS) of Xnview and XnviewMP and these two features (esp #1), I'd love to use this only instead of Xnview/MP, a comic reader and Neeview for dual panel image viewing. Thank you.
johnmy
Re: Auto Update and Continuous Display of 2 Images Side by Side at Once
Post by johnmy »
+1
auto update and install instead of go to web and download.
