Is there a way to 'Tag' or 'Rate/Colour' a folder?
Thanks
Tag Folder
Re: Tag Folder
why do you want to tag a folder?
You can rate/colour a folder in thumbnail view
Re: Tag Folder
for reference, folder's metadata per app:
- xnviewmp: rating, color label
- lightroom: color label
- acdsee: none
- faststone: none
ps. not sure if folder metadata is required at all
- acdsee: none
- faststone: none
klj
Re: Tag Folder
Thanks! I was expecting there to be an indication that it is coloured. Like a tag box or color box or something.xnview wrote: Wed Aug 23, 2023 9:41 am why do you want to tag a folder?
In the Details view, there is a "Colour label" column. But it is not showing the assigned color.
In the Details view there is also a Tag column with boxes that can be checked. But does not seem to work because I can't sort/filter on tagged folders.
klj
Re: Tag Folder
I am on Mac OS. When I assign a Rating/Colour to a folder it is not retained after quitting/restarting app.
klj
Re: Tag Folder
I've turned on Catalog with these settings and still no retention.
klj
Re: Tag Folder
I have found the label "indicator" I was expecting. The indicator/overlay colors are in 'Metadata'. But still no retention:
klj
Re: Tag Folder
To be clear: The Rating/Colour is retained for images, but not for the folders. I'm try to use the feature for folders.
klj
Re: Tag Folder
Just trying different things to get it to work.
I did find the solution. Sorting out the Integration tab fixed it up. Thanks so much for your help!
