Add new option to Output folder
sasko1
Post by sasko1 »
Hello.
I have a suggestion which would be rally helpful,
Is it possible to add another option to the Output Folder? Currently there are only two, source folder and Custom folder. I would really like to have also an option "Source subfolder" and an option to choose name of the subfolder.
I resize a lot of photos from different folders and I always want to have subfolder "Small" on each main folder I resize from.
So, with this feature, it would automatically create subfolder "Small" and put images there. Of course name must be an option to write in the interface.
Re: Add new option to Output folder
just write "Small" in Folder field
sasko1
Post by sasko1 »
user0 wrote: Sun Aug 27, 2023 3:38 pm just write "Small" in Folder field
If it is only one folder, it is OK. But if you do it for multiple folders, it is easier to have an option to just create subfolder of a source folder automaticly.
we're still in the suggestion forum, right? :twisted:
you didn't try like I said, did you?
sasko1
Post by sasko1 »
user0 wrote: Mon Aug 28, 2023 7:17 pm you didn't try like I said, did you?
Well, look at that! :shock: :mrgreen:
My bad, did not know this feature already existed. :mrgreen: I thought "Folder" always means to write the exact folder root. Everyday we learn something new.
Thanks for pointing me to it.
