Selected zoom percentage will not hold
josedumoretzsohn
Selected zoom percentage will not hold. I want to keep my zoom percentage at 70%, but this value always returns to 100% in the next image.
xmozg
Re: Selected zoom percentage will not hold.
Turn off "Reset 'Auto image size' setting with next/previous file" in options and turn on "Lock zoom" in a menu or a button added to the toolbar.
josedumoretzsohn
Thank you. Your instruction helped me a lot.
When was that setting introduced?xmozg wrote: Wed Aug 30, 2023 1:45 pm Turn off "Reset 'Auto image size' setting with next/previous file" in options...
Doesn't it defeat the purpose of Lock zoom, and if included shouldn't the default state be unchecked?
When Lock zoom has been selected, shouldn't unchecking it in the View menu automatically restore 'Auto image size' operation?
