Not a bug of XnView as it sounds but a /bugs/ in distributing packages.
It's a long age story.
Contents of installers and zips for both products, XnView and XnConvert, always differs.
For example, zip's have much more files than installers, XnViewMp zip have qtquickcontrolsplugin.dll in qml/QtQuick/Contols directory, but installer have this file in pluginsqml/QtQuick/Controls and I have no idea if this plugin is ever works/used in any of the "versions", zip or installer.
Cross-compare with XnView and XnConvert shows almost the same, but much more - XnConvert some files are outdated compared to XnViewMP files. And so on.
Looks like archives and installers are created from different sources or with different scripts.
.exe and .zip contents for XnView and XnConvert always differs
forklab
Re: .exe and .zip contents for XnView and XnConvert always differs
thanks i'll fix it
forklab
There is stil differences
forklab
Compare directories yourself.
There are enough differences in all 4 archives. Even if I compare only "inner" products - View vs View and Convert vs Convert. If I compare it vice-versa because they uses a lot of the same libraries it has much more differences.
Compare 1 vs 2, 1 vs 3, 1 vs 4, 2 vs 3, 2 vs 4, 3 vs 4.
Look at attachmets for quick look.
XnConvert is not yet updated
forklab
This is not Convert vs something. This is XnViewMP x64 vs XnViewMP x64. One is installer, another is archive. plugins/QtQuick/qmldir jumps from directory to directory, vcredist, China language
