1.5.3 ZIP file gets selected when using "Select All Images"
XnSoldier
Post by XnSoldier »
Strange behaviour of some ZIP files getting selected when using "Select All Images". I would assume they get selected by file extensions only.
I have archives which often use "store" as a compression and contain folders and JPGs only. I always use 7zip to compress. Many of such zip files on my drive get selected as images but not all. I don't know why.
In my download folder with random software and wordpress plugins as zip files none gets selected by "Select All Images".
I tested around with Zip "FileOne.zip" and If I extract all files and compress again with 7zip or File Explorer with either compression method the FileOne will not get selected as an Image again.
FileOne was compressed about a year ago with 7zip and is 400Mb in size before I make changes.
FileOne Changes done via Windows 10 explorer:
- I extract and recompress with 7zip. Gets not selected.
- I extract and recompress with File Explorer. Gets not selected.
- I delete all JPGs, leaving just an empty main folder in the zip with the json file and an empty subfolder. Gets not selected.
- I make a file copy. It gets selected also
- I add a json file to a subfolder. It still gets selected
- I either delete all subfolders or the JPGs in the main folder of the zip. It still gets selected.
- I delete all JPGs except one, checked with different JPGs I left last. Still gets selected
I cannot share a sample zip at the moment
Photographer. Sorting 100.000-250.000 pics per year
20 years with ACDSee Photo Professional. Love and Hate. I would love to see XnView MP upgraded for better editing or a commercial "XnPhoto Pro"! Keep up the great work!
Re: 1.5.3 ZIP file gets selected when using "Select All Images"
i can't reproduce, all image files are selected not the zip
XnSoldier
Post by XnSoldier »
It seems ZIP files created with ACDSee Pro 2021 get always selected as Images.
right, the zip is recognized as jpeg based
xmozg
Post by xmozg »
These zip files have jpeg headers inside and open as images even in irfanview and faststone. Problem with "store".
XnSoldier
Post by XnSoldier »
It should only be recognized by file extension I'd say
