v1.5.3 Incorrect color's from embedded raw preview.
FKCapitalism2
Post by FKCapitalism2 »
Preview images embedded inside RAW files show differently after being embedded.
.arw file looks too colorful
This both files .arw and .jpg display identical inside FastRawViewer and inside other image viewers like FastStone Image Viewer.
Source files: https://www.upload.ee/files/15638148/_DSC0074.zip.html
Re: v1.5.3 Incorrect color's from embedded raw preview.
Strange, it's the embedded jpeg from RAW file, there is no process
FKCapitalism2
xnview wrote: Fri Sep 01, 2023 8:14 am Strange, it's the embedded jpeg from RAW file, there is no process
Are you able to reproduce? Perhaps its some of my settings then?
yes, but don't understand why
