XNView 1.5.4 crashes
mapline
Post by mapline »
Hi updated to 1.5.4 and it loads and shows initial view. If I shows some folder its fine but if I show say desktop and some others it crashes.
Re: XNView 1.5.4 crashes
which file's format do you have in "problem" folders
mapline
Post by mapline »
One of the problems folders is my desktop in Windows 11 which has a varity of files and folders as shown in attached file.
I downloaded back to 1.5.3 and that is working without crashing. Hope this helps.
Kind regards Michael
mapline wrote: Thu Sep 07, 2023 10:17 am One of the problems folders is my desktop in Windows 11 which has a varity of files and folders as shown in attached file.
is it possible to have this folder?
mapline
Post by mapline »
Will do and send PM with link to OneDrive. Now uploading but so slow on my connection. :D
mapline
Post by mapline »
The link has been sent PM.
I had deleted a 1.5 gb file but tried 1.5.4 again and it still crashed. Some folders are ok but it crashes on other folders but always on the Desktop.
This problem is supposed to be fixed in XnView MP 1.5.5. Please check and confirm the bug fix here.
