1.5.4: moving image/dir does not move annotation
corr
Post by corr »
When I move a directory or image with annotation to another directory, the annotation is not moved with it. If I copy the directory or image, however, it works.
What is also inconvenient is that copied annotations are only displayed in the browser when you switch back and forth between directories.
Re: 1.5.4: moving image/dir does not move annotation
windows 10? do you move image with drag&drop from/into thumbnail view?
corr
Post by corr »
Yes, Win10.
Drag&Drop and CTRL+X/V in details and thumbnails view.
This problem is supposed to be fixed in XnView MP 1.6.0. Please check and confirm the bug fix here.
corr
Post by corr »
Tested in 1.6.1:
I gave directories an annotation and then moved (CTRL+X ) them to a directory above (CTRL+V). Unfortunately, the annotations are not moved with them.
right, reopened
This problem is supposed to be fixed in XnView MP 1.6.2. Please check and confirm the bug fix here.
