1.5.5: Text file still shown in viewer mode
fireattack
Post by fireattack »
I've noticed this bug in 1.5.3 and find the thread about it: viewtopic.php?p=190443
It's "fixed" in 1.5.4 but not for text file.
To repo:
Open the image.
Expected: go prev/next, it shouldn't show the text file content.
Observed: it shows text file. And it also hajacks left/right arrow which makes it more annoying since you can't easily go back.
finfet
Re: 1.5.5: Text file still shown in viewer mode
Post by finfet »
I have exactly the same problem with 1.5.3, 1.5.4 and the new 1.5.5
It's supposed to be fixed but it's not and it shouldn't open a text file.
I have gone back to 1.5.2 and it works perfect.
fireattack
user0 wrote: Sun Sep 10, 2023 6:36 pm 1.5.3 - viewer - browsing stuck at TXT file
Oh thanks, my bad for not searching first. I was fixated on viewtopic.php?p=190443 and thought surely it hasn't be reported if that ticket didn't fix it.
Edit: I guess there is a slight difference: that ticket is about buttons not working, but it shouldn't go to text file in viewer mode in the first place.
fireattack wrote: Mon Sep 11, 2023 2:59 am it shouldn't go to text file in viewer mode in the first place.
you can disable that in >=1.5.4:
Settings > View > Filter
Tetsuoo
Post by Tetsuoo »
user0 wrote: Mon Sep 11, 2023 4:13 am
Thank you I'll need to remember that, it was driving me nuts since 1.5.3. Once a text file is displayed you're basically stuck, can't show anything next so ESC was the only option.
XnView is great but there's TONS of settings in there so it's very easy to be lost and not notice the new ones
This problem is supposed to be fixed in XnView MP 1.6.0. Please check and confirm the bug fix here.
Tetsuoo
Post by Tetsuoo »
I had kind of a similar issue here, I wanted the texts to show up in the preview not in View mode. 1.60 fixed that even though "preview" option in prefs>file list no longer exist. So I don't know what's the magic here but I can confirm it works :)
Also I'm lucky to have this post in my tabs, version 1.60 is not ready yet for an official release I guess ? I already adopted it anyway ^^
Tetsuoo wrote: Sun Oct 15, 2023 3:08 am I had kind of a similar issue here, I wanted the texts to show up in the preview not in View mode. 1.60 fixed that even though "preview" option in prefs>file list no longer exist. So I don't know what's the magic here but I can confirm it works :)
checkboxes combined: visible in filelist = visible in preview (ref)
Tetsuoo wrote: Sun Oct 15, 2023 3:08 am Also I'm lucky to have this post in my tabs, version 1.60 is not ready yet for an official release I guess ? I already adopted it anyway ^^
guess due to some bugs
fireattack
Verified fixed , thanks
