1.5.5: Delete folder does not work properly
rhap4boy
Post by rhap4boy »
XnView: MP 1.5.5 - 64-bit
OS: Mac Ventura - 64-bit
XnView delete folder does not actually work
Effect: Folder does not get deleted
1. Right click on a folder
2. Select delete
3. Click Yes
4. Folder disappears from the tree
5. Close XnView and reopen XnView
6. Folder back again!
7. Folder still in Finder as well.
Actual behavior (bug): XnView only delete the folder from view.
Expected behavior: Folder gets deleted for real
Re: 1.5.5: Delete folder does not work properly
rhap4boy wrote: Wed Sep 13, 2023 3:47 pm 1. Right click on a folder
in folder or thumbnail view?
rhap4boy
Post by rhap4boy »
I just tried it again. If I right click on a folder on the folder tree view on the left, it will delete the folder temporarily but comes back. If I right click on a folder in thumbnail view on the right, it doesn't even delete the folder.
i've tried and can't reproduce. No rights problem? if you create a folder and try to delete it, same problem?
