WebP format has security issues
masterjp
Post by masterjp »
There is a security issue in webp format, which can produce a heap overflow.
All photo progams use an old webp library, which has this bug.
I think me must wait until the developer of the webp library has fixed the bug.
https://securityboulevard.com/2023/09/p ... tical-bug/
https://www.techtarget.com/searchsecuri ... nerability
Re: WebP format has security issues
it's fixed in libwebp v1.3.2
viewerr
Post by viewerr »
xnview wrote: Fri Sep 15, 2023 6:05 am it's fixed in libwebp v1.3.2
how do we install it?
I heard there are already exploits out there with prepared webp images?!
masterjp
Post by masterjp »
It is not possible to replace the libwebp.dll by yourself.
In the past you could use the library of XnConvert, if it used a newer library.
Please wait until the next release of XnviewMP.
P.S.: IrfanView 4.62 has the latest bug fixed webp 1.32. But you must install it manually.
It is not compatible with Xnviewmp.
please try to replace with this version
viewerr
Post by viewerr »
xnview wrote: Thu Sep 21, 2023 6:58 am please try to replace with this version
thanks!
seems to work :)
masterjp
Post by masterjp »
Wonderful! Thank you so much! :D
kesdoputr
Post by kesdoputr »
Hello, is the webp plugin has 32bits?
XnView MP x64 newest version is 1.6.2 with libwebp 1.3.2
but XnView MP x32 newest version is 1.5.5 and the libwebp still 1.3.0
Thanks for your reading.
ps.A suggestion, nconvert x64 now include webp plugin but x32 don't, maybe it's better that nconvert x32 also include the webp plugin. :D
kesdoputr wrote: Thu Nov 23, 2023 3:47 pm Hello, is the webp plugin has 32bits?
Here is with this version
ok
kesdoputr
Post by kesdoputr »
xnview wrote: Fri Nov 24, 2023 9:04 am
ok
Thanks for the reply, it works great. :D
