Subject: 1.5.5.0.XnView MP - escape/open XnView
XnView: MP 1.5.5 - 64 bit
OS: Windows 10 - 64bit
Using escape key to open explorer XnView from one image
Effect: Program hangs: Program close when I use the escape Key
1. open windows explorer
2. click on one image: XnView open with only this image
3. use escape key: XnView close (instead of opening XnView explorer)
Expected behaviour: possibility to use agan Escape key to open XnView explorer at the exact folder of the image opened (as in previous XnView versions)
Thanks
XnView MP 1.5.5.0 - Escape/open XnView [Solved]
mquentin
Re: 1.5.5.0.XnView MP - escape/open XnView
what do you have in Settings>Interface>Tabs & Settings>Interface>Keyboard?
mquentin
"Press ESC close"
and the check is for "view", not "explorateur"
(sorry I use french language for the program, I hope this is the correct translation))
please send screenshots?
mquentin
Finally, I simply unchecked "view" in Settings>Interface>Tabs & Settings>Interface>Keyboard and the problem is solved
I don't know this was checked automatically in this version
Thanks for your help
Gerhardus
Re: XnView MP 1.5.5.0 - Escape/open XnView [Solved]
Ich würde gerne diese Angaben umsetzen, aber ich finde schon „Ansicht“ unter „Einstellungen“ nicht. Da ich den gleichen Fehler habe, bitte ich um Hilfe.
Gruß
Gerhardus
Gruß
Gerhardus
