Info Panel add check "if exif value exists".
FKCapitalism2
Post by FKCapitalism2 »
inside Tools > Settings > View > Info tab can we add check for value being present in EXIF e.g.
if {EXIF:Focal Length} then {
   Focal Length: {EXIF:Focal Length}mm
} else {
   Focal length info missing
If value is there it will show block from true condition if not then show block from false condition.
Reason, when different cameras and lenses e.g. full manual lens does not have aperture or focal length inside exif, info window looks wrong showing info like "Focal length: mm" its just one example.
FKCapitalism2
Re: Info Panel add check "if exif value exists".
Note the empty GPS section on the bottom Lat: Lng: Altitude:
I want to show more information, but need to hide the lines missing values to save space and make whole info panel more readable.
Now it shows too much text that has no relationship to the current image taken with mirorrless camera, that text only related to images from phones that would have GPS so best its hidden if has no value.
Image from this post.
