1.5.5 - viewer - statusbar - embeded comment has wrong vertical position
XnViewMP 1.5.5 64bit
Viewer - statusbar
test_img_comment.zip
(824 Bytes) Downloaded 238 times
Re: 1.5.5 - viewer - statusbar - embeded comment has wrong vertical position
you have a return character in the comment
ah.. right
however, it should not be shown like that, since:
- it does not look nice, and statusbar is not sizable to view such content without hassle
- it shows only first 2 lines, but not the followin lines, so why bother
options:
a - always how only 1st line
b - ignore return character and show all paragraphs as single line
c - always show only 1st line, but add some indicator that there are more lines
fixed in 160b
This problem is supposed to be fixed in XnView MP 1.6.0. Please check and confirm the bug fix here.
