v1.5.5 Incorrect dimensions shown on info tab
FKCapitalism2
Post by FKCapitalism2 »
When open .jpg file that is 64MP in size first XnView MP shows 1MP file,
then in one second shows 64MP file
cicciobello
Re: v1.5.5 Incorrect dimensions shown on info tab
Post by cicciobello »
The same happens in full screen.
A minor definition appears momentarily, and then the correct one.
it's not the file size but the image size
FKCapitalism2
xnview wrote: Mon Sep 25, 2023 6:02 am it's not the file size but the image size
First XnView MP display low resolution image before higher resolution image is loaded?
FKCapitalism2 wrote: Mon Sep 25, 2023 7:20 am First XnView MP display low resolution image before higher resolution image is loaded?
yes
