I guess it should be identical.
X.
XnView 1.82 -
b3 Edit>Metadata submenu different in Browser and View
Xyzzy
Re: b3 Edit>Metadata submenu different in Browser and Vie
Some menu item are specific to batch (copy comment...)Xyzzy wrote:I guess it should be identical.
Xyzzy
They should work simply on current image/file sequence in View.
If it is not possible, they should be simply inactive.
There is no reason for these menus to be that much different.
Curretly they are:
Set comment
Copy comment to IPTC Caption
Copy IPTC Caption to Comment
Copy EXIF USer Comment to Comment
Edit IPTC Data
<exporting metadata>
Clean
Edit IPTC data
Remove IPTC data
Remove EXIF Thumbnail
Remove EXIF Data
Remove all metadata
BTW, all Remove options in View are covered by Clean option in Browser.
X.
[/code]
Curretly they are:
Set comment
Edit IPTC Data
Clean
Edit IPTC data
Remove IPTC data
Remove EXIF Data
Remove all metadata
X.
[/code]
Edit Metadata in view and browser don't work in the same way. In view mode you change metadata on loaded picture (no change on file), and in browser you change filesXyzzy wrote:They should work simply on current image/file sequence in View.
Curretly they are:
Set comment
Edit IPTC Data
Clean
Edit IPTC data
Remove IPTC data
Remove EXIF Data
Remove all metadata
X.
[/code]
Xyzzy
Xyzzy
Xyzzy
I do not understand why in Browser 'Set comment' is in 'Metadata' submenu and in View it is as a stand-alone item of 'Edit menu' (and its name is 'Edit comment').
I do not see any reason for such distinction.
I think the item should be named 'Edit comment' in both places and be placed in Metadata submenu (because it edits image embedded metadata).
The rest is OK.
Reopen.
X.
The rest is OK.
Reopen.
X.
marsh
Hello Xyzzy, they are different. One is a lossless jpg operation. The other 'edit comment' is not.Xyzzy wrote:I do not understand why in Browser 'Set comment' is in 'Metadata' submenu and in View it is as a stand-alone item of 'Edit menu' (and its name is 'Edit comment').
The rest is OK.
Reopen.
X.
Xyzzy
