1.5.5 - edit GPS Data - delete original file does not work!
dermaik
Post by dermaik »
XnView MP 1.5.5 - 64 bit
OS: Windows 64bit
When I edit the GPS data, the original files are not deleted, there are .jpg_original left.
Re: 1.5.5 - edit GPS Data - delete original file does not work!
Post by michel038 »
Check if jpg files (or folder) are write-protected ?
dermaik
Post by dermaik »
File and folder are not write protected. I also tested it in different folders and drives.
cicciobello
Post by cicciobello »
Same problem, but this is an old problem. Or "feature".
By now I'm used to deleting duplicate files after entering the GPS coordinates.
Post by michel038 »
Unmark :
Settings>General>File operations>"Make backup for other lossless operations"
(if it was checked :mrgreen: )
dermaik
Post by dermaik »
Thank you. Too many options. :D
cicciobello
Pfff! :-O
