the text in print is cut off as you can see in the attached picture.
could find the problem elsewhere, but it might already exists in this forum - sorry, if so.
tried everything, but nothing worked ... anyone an idea how to fix this? thx.
Text in print is cut off at the bottom
arkitekt
Re: Text in print is cut off at the bottom
try to set windows display scale to 100%
1.3.1 - print - windows scale affects text | default caption
arkitekt
thx, you are right, its the windows display scale, but i cant change it on my 4k montior ...
any other solution? i guess i am not the only one with a 4k montior ...
