Tab navigation?
codeslake
Tab navigation?
Post by codeslake »
Hi, I've recently been using this amazing app.
I wonder if there is way to navigate between tabs (e.g., ctrl-tab for next tab, ctrl-shift-tab for previous tab as in the most tab-supported programs).
Re: Tab navigation?
you have CTRL+TAB
codeslake
Re: Tab navigation?
Post by codeslake »
Oh, I didn’t mentioned the OS. I al using macos (ventura) but the key isn’t working.
Re: Tab navigation?
yes it's an issue on MacOS
