Settings - browser - thumbnail - remove Custom size checkbox
Re: Settings - browser - thumbnail - remove Custom size checkbox
so 'thumbnail custom size' => 'Thumbnail size'?
xnview wrote: Sun Nov 05, 2023 2:33 pm so 'thumbnail custom size' => 'Thumbnail size'?
what do you mean ? :D
my idea - it is not required to have checkbox in Settings, because it should not control which item is selected in Browser's 'Thumbnail size' menu.
  • In Settings
    - controls in 'Custom thumbnail size' group are always enabled
    - you only set sizes for Browser's 'Custom' item
  • In Browser
    - no any changes, you just select any predefined size or 'Custom' option when required
This problem is supposed to be fixed in XnView MP 1.6.2. Please check and confirm the bug fix here.
fixed in 162
