Alphabetical sorting is repeatedly broken/overriden by folder browser sorting
postcd
Post by postcd »
DETAIL:
when i use
XnView MP 1.5.5 64 bit Linux LibFormat 7.155 (Linux .deb)
folder browser/explorer tab and click to sort files for example by file type or date, then quit XnView and then later open an image using my OS file manager and use XnView left/right arrow keys to browse to other files in same folder, it does not browse alphabetically which is what i want to happen on each new start of the XnView.
SUMMARY/ISSUE:
Apparently XnView remembers my sorting method used in XnView folder browser (clicking column header) and sets it as a "global" default.
IDEA:
It would be handy to allow user to set default sorting method inside Settings and override this method (via folder browser, column header) only for current session while default global setting (in Settings) would be set to Alphabetical. This would seem more logical that default sorting is set in Settings and folder browser override only for current session.
Linux user, .deb package. Use private services like Proton.me, not surveillance services like Google, Meta.
Re: Alphabetical sorting is repeatedly broken/overriden by folder broser sorting
i can reproduce only when using 'sort by Type', but not Date or Filesize
postcd
Post by postcd »
xnview wrote: Thu Oct 05, 2023 9:34 am i can reproduce only when using 'sort by Type', but not Date or Filesize
I have just tried and for me the "last change date" (i am using non-english language) and "size" also changes the new new default viewing order across current and future sessions (wrong behavior IMO as described).
But even if you can reproduce behavior on ordering by "Type" only, maybe you can consider changing the OP described XnView MP behavior.
you are able to reproduce when using Sort>Filesize??
postcd
Post by postcd »
xnview wrote: Thu Oct 05, 2023 10:35 am you are able to reproduce when using Sort>Filesize??
"Size" column in XnView MP folder browser:
and also when i do "View" > "Sort by" > "File size"
i've tried to sort by filesize, and open an image tab and sorting is correct (like browser)
postcd
Post by postcd »
xnview wrote: Mon Oct 09, 2023 7:53 ami've tried to sort by filesize, and open an image tab and sorting is correct (like browser)
Same for me, and that is right, but only for current session. When you read my OP (original post, first one), I am criticizing that it modify default sorting for next sessions.
postcd wrote: Mon Oct 09, 2023 11:26 am
yes it's normal, the sort method is saved for next session...
postcd
Post by postcd »
xnview wrote: Tue Oct 10, 2023 6:30 amthe sort method is saved for next session...
