create error/saving error
Terdlestuff
Post by Terdlestuff »
hello, I am trying to convert the layers in a psd file into seperate png files for a project, but i am getting a "create error" on each file no matter what i try
Re: create error/saving error
no rights issue??
Terdlestuff
xnview wrote: Thu Oct 05, 2023 2:57 pmno rights issue??
i got it from here https://www.xnview.com/en/xnviewmp/, is that not the right place?
sorry, but you have not a rights problem with output folder?
Terdlestuff
i might not be understanding what you mean, but i got the program off of the official website so i dont think i should be having an issue with rights, im using it for a personal project and am not part of a company, and the liscense says i have the rights to use the program
Are you able to open an image directly in the XnView MP viewer using the long path ... terdle.psd (48) 240x279x32 ?
That, despite the fact that the file is shown as being loaded in Batch convert, seems an unusual path unless maybe I am missing something.
Also, XnView MP doesn't fully support the PSD format, and I am not sure if there is any support for viewing individual layers?
Terdlestuff
ohhhhhh that makes sense, thank you
cday wrote: Fri Oct 06, 2023 8:58 pm Also, XnView MP doesn't fully support the PSD format, and I am not sure if there is any support for viewing individual layers?
it works with my few multilayer psd files
Terdlestuff wrote: Thu Oct 05, 2023 2:16 pm hello, I am trying to convert the layers in a psd file into seperate png files for a project, but i am getting a "create error" on each file no matter what i try
try to do the same from other folder, eg ..\Desktop\1 or c:\1
if it does not help you can post your file here (delete/blank all sensitive info there)
