Edit XMP many fields are not saving
FKCapitalism2
Post by FKCapitalism2 »
Inside Metadata > Edit XMP window many fields are not saving.
Keywords tab is broken, not saving keywords, keywords not add with hierarchy if use | character.
Origin tab following fields marked red are not saving.
However it does save to image metadata, its just this fields not show afterwards in XnViewMP and don't load if using Update catalog from files
[IPTC:Location] City
[IPTC:Author]   Credit
[IPTC:Author]   Source
[IPTC:Other]    Headline
[IPTC:Other]    Urgency
IPTC Contact tab - no fields are saving.
IPTC Extensions tab following fields marked red are not saving.
XMP FWC tab - no fields are saving.
Options tab Mode drop-down makes no difference, both XMP & IPTC are written regardless of selection.
Re: Edit XMP many fileds are not saving.
i can't reproduce. Please send me the ARW file with .xmp companion used?
FKCapitalism2
xnview wrote: Fri Oct 06, 2023 8:45 am i can't reproduce. Please send me the ARW file with .xmp companion used?
There is no XMP companion XnViewMP writes straight to the .arw file regardless of options i select.
File i tested on https://www.upload.ee/files/15772839/_DSC0001.zip.html
Re: Edit XMP many fields are not saving
FKCapitalism2 wrote: Thu Oct 05, 2023 6:46 pm Keywords tab is broken, not saving keywords, keywords not add with hierarchy if use | character.
I use ExifTool to update RAW, but it updates only IPTC not XMP datas...
These fields are not supported by ExifTool
FKCapitalism2
xnview wrote: Fri Oct 06, 2023 3:32 pm
I don't understand what you mean.
Regarding Origin tab fields i said are missing are written inside .arw file, however they are not displaying when i open back Metadata > Edit XMP
They saved to this fields inside .arw file
and displayed in Info panel IPTC tab.
which is fine with me i just want to see them displayed when i go back to Metadata > Edit XMP.
xnview wrote: Fri Oct 06, 2023 3:32 pm These fields are not supported by ExifTool
Also please note Options tab Mode drop-down makes no difference, is it supposed to create .xmp sidecar when "XMP" option selected?
I tested both options and it just writes both XMP & IPTC fields into ARW file regardless of selected option.
FKCapitalism2 wrote: Fri Oct 06, 2023 3:45 pm
ExifTool seems to update only IPTC/Urgency and not XMP:Urgency
No, it's to sync between IPTC and XMP metadatas (XMP can be embedded or external .xmp)
This problem is supposed to be fixed in XnView MP 1.6.0. Please check and confirm the bug fix here.
