Search Ctrl+F has limited number of tags available.
FKCapitalism2
Post by FKCapitalism2 »
I wanted to search images by some tags that are available for info window in General > View > Info however for Search window they are not available.
In particular.
[EXIF:Camera]		Exposure Mode
[MakerNotes:Camera]	Sequence Number
[MakerNotes:Camera]	Release Mode
[MakerNotes:Image]	Release Mode 2
[MakerNotes:Image]	Release Mode 3
[MakerNotes:Image]	Sequence Length
As for EXIF:All Fields how do i use it? If i am looking for [EXIF:Camera] Exposure Mode (values are Auto bracket or Manual) i type "Auto Bracket" in EXIF:All Fields and nothing is found.
Re: Search Ctrl+F has limited number of tags available.
Exposure Mode should be added, currently search can't work with Makenotes
FKCapitalism2
xnview wrote: Sat Oct 07, 2023 10:47 am Exposure Mode should be added, currently search can't work with Makenotes
You mean you will add it in next version of XnView?
Is there reason why you not want to add additional fields available in General > View > Info, from what i understand they are already stored in catalog?
FKCapitalism2 wrote: Mon Oct 09, 2023 9:42 am You mean you will add it in next version of XnView?
Yes
Makernotes are not stored in catalog
FKCapitalism2
Tried on Exposure Mode on v1.6.1 and it does not work, it was not added or i doing something wrong?
not yet added
FKCapitalism2
xnview wrote: Tue Nov 21, 2023 9:24 amnot yet added
guess its not yet in v1.6.3
