1.5.5 - viewer - statusbar - shows comment from prev file
XnViewMP 1.5.5 64bit
Viewer - statusbar
prev file's comment shows until mouse move within view area
0. have 4 test files in folder, 1 and 2 have embeded comments
test_img_comment.zip
(6.86 KiB) Downloaded 205 times
1. open 1.jpg image in viewer
viewer will still show comment from previous file in statusbar
if you move mouse within view area - correct comment (blank) will be shown
if current file has comment - no issue
Re: 1.5.5 - viewer - statusbar - shows comment from prev file
you can always reproduce???
100% reproducibility
try keyboard arrows to scroll files (1,2,3) because as soon as you move mouse comment will be changed to corect "blank" one
i can't. With clean ini?
yep,
clean unzipped version with ini/db files inside app folder
This problem is supposed to be fixed in XnView MP 1.6.0. Please check and confirm the bug fix here.
fixed in 160
