Personalizable IPTC / Global next image shortcut
SoulePhoto
Post by SoulePhoto »
It would be great if the IPTC module was personalizable. Being able to move fields from one tab to another would be helpful. Some tabs seem like they could be in one. Or add a custom tab so you could add the fields you need. When editing groups of photos most fields are going to be the same value, but the Caption and keywords will be different for every image. Being able to have them on the same tab would help out a lot.
Also the next image shortcut (ctrl + right arrow) inside the IPTC module doesn't work while active in a text box. It moves the curser to the next word instead. You have to click away from the text box for it to work. Not having move back and forth to the mouse would help.
