Selection Ratio - shortcutable?
meteorquake
Post by meteorquake »
It would be very handy if the viewer Selection Ratio choices under Edit - Selection Ratio could be user-assignable to shortcut keys.
Also is there a way to manually type the selection size? I would have anticipated an item called Custom... or else Same as Selection (so the current ratio gets locked for future use)
Cheers! David
