In the file list => custom filter there is a table of file formats with a column '6'. What does it mean?
Furthermore in Column 'open with' you can find 'XnView'. Maybe you want to rename it in XnViewMP,
because this is the name of the program. XnView is another software.
XnViewMP 1.5.5 - Settings menu - file list - table with column '6'
masterjp
Re: XnViewMP 1.5.5 - Settings menu - file list - table with column '6'
