XnView MP 1.5.5 - Batch convert files are not sent to recycle bin
crushboy92
Post by crushboy92 »
Hello, I've been using XnView MP for a long time without problems, but in the 1.5.5 version, when I batch convert files (JPG and PNG to JPG - JPEG / JFIF), they are not always sent to the recycle bin (I would say 40-60% are not sent to the recycle bin right now): it's like they are completely gone, with no option of recovering them later (but if I go one by one, I believe they are always sent to the recycle bin). The older versions of XnView MP always sent all the deleted files (after batch converting them) to the recycle bin without any problems. I don't see any misconfiguration in the batch conversion section comparing to the older versions (delete the original file is checked) and the use recycle bin checkbox is checked in general settings, so I don't know where is the problem.
PS: I use XnView MP in Spanish, so I don't really know if the options I mentioned are named like I wrote. I use Windows 11 and the folders are all in the C: drive.
Re: XnView MP 1.5.5 - Batch convert files are not sent to recycle bin
This problem is supposed to be fixed in XnView MP 1.6.0. Please check and confirm the bug fix here.
crushboy92
I'm experimenting the same issues after changing to 1.6.0. I don't know if it's related to updating Windows 11 this week. I think I had to update twice in a few days span (they were required, with the typical orange point). The layout of the recycle bin and the Windows explorer changed a little bit, but anyway, after batch converting some pics this same morning, with the parameters of my last attachment, I refreshed several times the recycle bin looking for some of my recently deleted png's and jpg's and I believe that the proportion of files that are not sent to it stays the same as my previous post, around 40-60%, maybe even higher. The two checkboxes that I indicated previously were also checked.
My desktop is an ASUS TUF Gaming A15 FA506IU_FA506IU, Windows 11 Home, 22H2 version, OS version 22621.2428
your drive uses recycle bin?
crushboy92
Yes.
crushboy92 wrote: Fri Oct 13, 2023 7:34 pmYes.
i send you a PM
