1.6.0 - settings - few Thumbnail related issues
XnViewMP 1.6.0 64bit
Settings
issue A
issues appears only if no Browser tab has been opened in current session
1. open image in Viewer mode via doubleclick in win file exlorer
2. goto Settings
3. click on Thumbnail - app will crash
crash_dump.zip
(24.56 KiB) Downloaded 238 times
issue B
2. open Browser mode
3. goto Settings > Browser > File list > Custom filter tab
4. check/uncheck "Show as Thumbnail" in Video row (its unchecked by default)
5. press OK
app will hang
if you kill the process and start app - "Show as Thumbnail" will be checked
if do steps 3-5 in Viewer mode - app do not hangs, but once Browser mode is opened - progress bar stuck at ~30-32% (mybe it just generates too slowly)
also the following message appears on the next run, guess due to force closed at thumbnails generation stage, but leaving active background process
if background process force closed as well - no more message
issue C
depends on B, if "Show as Thumbnail" is checked - no issue
3. select video file
4. press "Video thumbnails gallery..." in Create menu
5. press OK
app stuck at generating popup
5. press ESC
app will close silently
on the next start - no issue for the 1st time generating video thumbs, 2nd time - stuck again
Re: 1.6.0 - settings - few Thumbnail related issues
user0 wrote: Thu Oct 12, 2023 1:57 pm issue A
1. goto Settings
2. click on Thumbnail - app will crash
Always? I can't reproduce
issue C
Video thumbnails gallery stuck at generating popup
what do you means?
added some details
A - always
B,C - depends on conditions
2. goto Settings
crash_dump.zip
Seems related to icons added in 'Overlay icons', but i can't reproduce :(
issue B
5. press OK
app will hang
You have video files in current folder?
issue C
5. press OK
5. press ESC
Please send the video file used?
xnview wrote: Thu Oct 12, 2023 3:57 pm
try to 1. open image in Viewer mode via doubleclick in win file exlorer
it looks like if Browser tab has been opened previously in current session - no issue A
issue B
issue C
B,C caused by this file, that I cut to 4sec (by keyframe) via LosslessCut,
no issue with original uncut file
weatherman_cut_4sec.mp4
(1.21 MiB) Downloaded 248 times
xmozg
Post by xmozg »
user0 wrote: Thu Oct 12, 2023 1:57 pm To reproduce:
issue A
2. goto Settings
Same here. In my case crash also occurs when I open browser mode with
startupType=0
I.e. without files visible in browser. If I open any folder then no crash.
And by the way, in the previous version 1.5.5, when startupType=0 was enabled, a folder from a previous session was displayed in the address bar, although it did not open automatically. This was convenient for me, because... in case I wanted to open a folder from a previous session, I just had to press enter in the address bar. Now with startupType=0 the address bar is empty. Something has changed.
its offtop here, but..
xmozg wrote: Fri Oct 13, 2023 2:08 am And by the way, in the previous version 1.5.5, when startupType=0 was enabled, a folder from a previous session was displayed in the address bar, although it did not open automatically. This was convenient for me, because... in case I wanted to open a folder from a previous session, I just had to press enter in the address bar. Now with startupType=0 the address bar is empty. Something has changed.
changed base on:
1.4.5 - browser - file list toolbar - recent paths purge - issue A
its correct behavior from several points of view: consistency and privacy
"Open Browser with Directory - None" (startupType=0) means no path shall be left in Browser on open, especilly if there is "Last" available as the next option.
If you want to have Last path in Browser, but not load it - that shall be achieved via different means, eg extra "load path" checkbox or just use Favourites.
2. goto Settings
Please make a new post
xmozg
Post by xmozg »
user0 wrote: Fri Oct 13, 2023 4:58 am its correct behavior from several points of view: consistency and privacy
"Open Browser with Directory - None" (startupType=0) means no path shall be left in Browser on open, especially if there is "Last" available as the next option.
This is "correct" only for those who need "complete confidentiality." But I don’t need it - it’s enough for the files not to be displayed, while the path should be saved; anyway, people passing by won’t see it.
"This shall be achieved by something that does not exist" 👍
But I can live without this feature, so to speak.
xnview wrote: Fri Oct 13, 2023 6:12 am :bugconfirmed: Thanks to your detailed description I can reproduce the problem.
:bugfixed: Good :mrgreen:
issue B
issue C
This problem is supposed to be fixed in XnView MP 1.6.1. Please check and confirm the bug fix here.
all fixed in 161
