XnView Ver 1.4.3 Cut Selection invert randomly on TIFF files
SandUhrGucker
Post by SandUhrGucker »
1st thank you for this great piece of software (!)
I found a strange bug in XnView:
Task is to mask, cut & save 300 Images.
On JPG & PNG this works fine, on TIFF Files the selection invert randomly after some files.
System:
Windows 10
XnView Ver 1.4.3 64bits (Feb 25 2023)
ffmpeg version N-111383-g20b8688092-20230709
built with gcc 13.1.0 (crosstool-NG 1.25.0.196_227d99d)
Here you can see the problem: https://youtu.be/vOrSGxMITq8
Regards,
Rene´
Re: XnView Ver 1.4.3 Cut Selection invert randomly on TIFF files
could you send me a TIFF sample?
