XnConvert -- Update check not working (portable)
m-london
Post by m-london »
The update checker in XnConvert does not seem to be working, at least in the portable version...
Additional Info...
  • I use the portable version of XnConvert (i.e. the extracted .zip, rather than the installed version)...
  • I was using v1.96 which is set to check for updates "weekly"
  • I haven't received any update notifications over the last few months using XnConvert
  • However, doing a manual check earlier saw that v1.98 came out months ago! :?
Re: XnConvert -- Update check not working (portable)
right, will be fixed
