Copying pictures is invalid
alee001
Post by alee001 »
Pressing Ctrl+C and Ctrl+V to copy the image will not work in any image format.
XnView MP v1.6.1 64bit windows
masterjp
Re: Copying pictures is invalid
Post by masterjp »
Please try:
Ctrl+C and Ctrl+Shift+V
Then you get a copy of your picture or from clipboard!
PC: Intel 8700k + Asus Z370-F + 16 GB RAM G.Skill + Asus RTX 3050 OC + Samsung SSD
OS: Windows 10 Pro 64bit 22H2 |
GFX: XnViewMP 1.8.7 | XN-View 2.52.0 | XnConvert 1.104.0 | Adobe Photoshop Elements 2024 | Elements XXL 11 | Paint.Net 5.1.7
alee001
Post by alee001 »
The copy action will flash the dialog box for 0.5 seconds (as shown in the picture) and show that the copy is completed, but there is actually no copy?
even if you refresh the folder? No rights problem in this folder?
alee001
Post by alee001 »
Pressed refresh and there is no copy even in File Explorer.
The previous version copied normally.
if you try 1.6.0, no problem?
alee001
Post by alee001 »
xnview wrote: Fri Oct 20, 2023 6:55 am if you try 1.6.0, no problem?
I don't have the previous version, but I have v1.5.0, and it has been confirmed that 1.6.1 has this problem.
alee001 wrote: Fri Oct 20, 2023 2:16 pm I don't have the previous version
you can get it here:
https://download.xnview.com/old_versions/
alee001 wrote: Fri Oct 20, 2023 2:16 pm I don't have the previous version, but I have v1.5.0, and it has been confirmed that 1.6.1 has this problem.
I can't reproduce this problem, if you drag&drop a file from windows explorer to XnView's browser, is it working?
alee001
Post by alee001 »
xnview wrote: Sat Oct 21, 2023 7:33 am
Maybe it’s a bug extension name?
I found that if the interface is set to English, a copy can be seen in both Programs and File Explorer. sample.jpg>Copy of sample.jpg
However, if the interface is set to Chinese, the copied copy cannot be seen in the program, and an incorrect copy can be seen in the file manager(cannot open). sample.jpg>sample.jpg的副本
alee001 wrote: Sat Oct 21, 2023 6:37 pm However, if the interface is set to Chinese, the copied copy cannot be seen in the program, and an incorrect copy can be seen in the file manager(cannot open). sample.jpg>sample.jpg的副本
The filename template used is
<filename><ext>的副本
and should be
<filename>的副本<ext>
right?
alee001
Post by alee001 »
xnview wrote: Sun Oct 22, 2023 7:37 am
<filename><ext>的副本
and should be
<filename>的副本<ext>
right?
I know the file name template, but the template set in the Chinese interface is not what I expected as shown in the picture: Copy(#) of <檔案>
ok, there is a problem in translation
This problem is supposed to be fixed in XnView MP 1.6.2. Please check and confirm the bug fix here.
alee001
Post by alee001 »
xnview wrote: Wed Nov 22, 2023 10:24 am This problem is supposed to be fixed in XnView MP 1.6.2. Please check and confirm the bug fix here.
Yes, it work.
