psd, heic types cannot be previewed
ebfming
Post by ebfming »
hi everyone
I recently found a problem using XnViewMP and need your help
When opening psd or heic format, I find that I cannot preview it unless I open it through a browser. If it is jpg format, there is no problem.
System: windows 10
Software version: 1.6.1
Re: psd, heic types cannot be previewed
If you have a problem when double clicking a file from desktop or windows explorer, please check registry entry for .heic/.psd
ebfming
Post by ebfming »
xnview wrote: Sat Oct 21, 2023 7:59 am If you have a problem when double clicking a file from desktop or windows explorer, please check registry entry for .heic/.psd
Thank you very much for your answer
I tried to run Associate files with XnViewMP.exe as root to register all file types, but I still received a cold warning from the system: File association cannot be changed. Please make sure you have administrator rights
I checked the extension association of Windows and found that .psd has been associated with xnviewmp.exe, but the problem was still not solved.
'Associate file with XnView' is only for windows 7, please registry entry
